Power surge can affect a PC
Power outage can't for the most part
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1210656-power-outage/#findComment-13728536
usually outage & sudden shutdowns generally don't cause any hardware problems unless happening repeatedly & too often.  other than you loosing unsaved documents this randomly happening is no problem at all. try getting a mediocre UPS for the least to sustain power & gives you time to shut down stuff properly.
Details separate people.
https://linustechtips.com/topic/1210656-power-outage/#findComment-13728546
On 6/17/2020 at 10:15 AM, -WHIZ- said:
So this morning my pc was off when my power went out, im pretty worried my pc is running good now but im still a bit worried
On 6/17/2020 at 10:28 AM, -WHIZ- said:
This power outage was for the first time ever
I wouldn't worry. As others have stated, it's unlikely there would be much of an issue unless unexpected shutdowns become habit; most modern electronics have several fail safes built in to prevent damage from sudden losses of power. Surges on the other hand can be quite dangerous, but in your case it seems all is well. You may have lost anything that wasn't saved but other than that you're fine.
https://linustechtips.com/topic/1210656-power-outage/#findComment-13741540
