I FUCKING FIXED IT!
well, after getting a new psu, removing EVERYTHING but psu, mobo, cpu, gpu and FANS, swapping my H115i for the stock amd cooler...
The problem persisted.
In a desperate attempt to fix this hellish pc, I tore gpu and mobo apart down to the PCB, washed everything with PCB-cleaner and a toothbrush, waited 12 hrs, repasted and reassembled everything, and wouldn't you know it, somewhere in my system seemingly was a tiny piece of conductive material that shorted something out whenever it felt like it. At least that's what I think happened.
Hello dear community!
I, once again, desperately need your help...
I tore apart and rebuilt my system on Sunday.
The only things I added were a 5" display for system info readout, a corsair h115i, and I swapped my China rgb fans for 2x QL 140 and 3x LL 120. Thus I also installed a corsair commander and a lighting node.
Since Monday I suffered 4 system reboots, of which I witnessed one. The others occurred while I wasn't in the room or asleep.
Onto the specs:
Ryzen 5 3600
Asus Prime x470-pro
16gb corsair vengeance rgb pro
Crucial P1 500gb nvme ssd
Crucial P1 1tb nvme ssd
2x 1tb ssd (1x WD, 1x SanDisk)
Gigabyte aorus 2080 super waterforce
Corsair HX850i
-Crystal disk says my drives are fine
-I installed new nvidia drivers Saturday, the day before the rebuild.
-I never had anything like this occurre before.
-There are no OCs in place.
-The restarts seem to happen totally random (was using the system for 3-4h last evening without issue, used it to listen to an audio book when I went to bed, woke up to it having restarted again, tried googling some fixes once more, and then it restarted again while I did)
-there are no BSODs, it just goes black and restarts
-Temps are fine. Cpu and Gpu idling at around 35°C +/- some degrees
I am really am at the end of my wisdom and I am just extremely frustrated. I wanted to have my build log updated by now as the system is now what and how I always deemed it to be, but instead this possessed piece of tech keeps crapping all over me ^^
If anyone has any ideas, fixes, experience... Please help me out here. If something is unclear feel free to ask.
Any help is greatly appreciated
My Rig / Buildlogs:  ❄️ SNOWFLAKE ❄️ FROSTBITE ❄️
CPU: Ryzen 5 3600   Cooler: Corsair H115i Platinum   RAM: Corsair Vengence RGB Pro 16GB @3200   Mobo: Asus Prime X470 Pro
Graphics Card: Gigabyte Aorus 2080super Waterforce    Case: Corsair 500D   PSU: Corsair HX850i
Storage: 500GB Crucial P1 NVMe SSD, 1TB Crucial P1 NVMe SSD, 2x 1TB SATA SSD
Displays: AOC CQ32G1 32" 2560x1440, Acer XB280HK 28.0" 3840x2160 60 Hz, Medion MD20850 24" 2560x1440
https://linustechtips.com/topic/1210506-solved-kernel-power-id-41/
although I haven't had your specific issue before, there's a few things that you could try. make sure your OS, your drivers, and your BIOS are up to date. sometimes newer versions fix stability issues.  also, sometimes dirt or hair can get inside a socket and can cause issues. make sure your CPU your GPU, and your RAM slots are all clean.
Ty for your quick response!
Will follow your suggestions when I get home from work
also, super cool looking build.
Ty again 😃
  • 3 weeks later...
after 3 weeks of extensive testing and research my problem still persists =(
  • 3 weeks later...
Fixed 😃
