Replacement GPU Fans
Go to solution Solved by jaslion,
If the connector is the same then go for it. It's hard to see on any things I find about the 980 so best if you look in person and see if the connectors match up with the ones in the image. They should as these are for all intents and purposes the same fans.
Hey guys
My friend has a Gigabyte 980Xtreme 4 and one of the fans has done a bearing so I've disconnected it and it's running okay but would like to get that fan replaced. The closest I could find look very much the same but for a different model so I was wondering if anyone here could confirm.
Thanks guys
https://www.ebay.com.au/itm/3x-Cooling-Fan-Lufter-fur-Gigabyte-GTX1080ti-1080-1070-1060-75MM-T128010SU-0-35A/114190509006?_trkparms=aid%3D1110006%26algo%3DHOMESPLICE.SIM%26ao%3D1%26asc%3D20200520130048%26meid%3D6f48476ea2404b7b930fc9868187addf%26pid%3D100005%26rk%3D1%26rkt%3D12%26mehot%3Dco%26sd%3D392490385445%26itm%3D114190509006%26pmt%3D1%26noa%3D0%26pg%3D2047675%26algv%3DSimplAMLv5PairwiseWebWithBBEV2bDemotion%26brand%3DMarkenlos&_trksid=p2047675.c100005.m1851
https://linustechtips.com/topic/1210166-replacement-gpu-fans/
https://linustechtips.com/topic/1210166-replacement-gpu-fans/#findComment-13724468
Yeah the connector is identical.
Thanks for the confirmation ^-^
https://linustechtips.com/topic/1210166-replacement-gpu-fans/#findComment-13727204
