Help on my first build
Go to solution Solved by vinit6694skr,
39 minutes ago, Jvysuu said:
Budget (including currency): Php55k ($1100)
Country: Philippines
Games, programs or workloads that it will be used for: Apex Legends, Red Dead Redemption 2, CSGO, and future AAA Games
Hi I am from the philippines and english is not my first language so im sorry in advance for any grammar error.
I will be building my first pc in maybe 2 months mostly for gaming, schoolwork and maybe a little bit of editing. This is the parts i still need an OS and a monitor. I will be posting the prices in our currency and the price of parts here with the convversion to usd
CPU: 3300x - php6950 ($136)
MOBO: msi tomahawk max - php6400 ($126)
RAM: G.skills ripjaws 2x8 3600mhz - Php3800 ($75)
GPU: Gigabyte GTX 1660 super - Php13950 ($274)
PSU: Seasonic m12ii 620W 80bronze - Php3600 ($71)
SSD: WD green m.2 480Gb - Php2950 ($58)
Case : NZXT h500 - Php3950 ($77)
OS: Windows 10 Pro - php8850 ($173)
Monito: Benq Ew2480 ips 1080p 5ms response time - php7110 ($139)
is this parts good? And if youre asking why only 480gb ssd and no other storage im planning to add more in the future if i need it because the money will just be for starting just to get back into pc gaming. ill upgrade the cpu in the future and add more storage if needed. And will this build last for maybe 4 to 5 years before i upgrade again
As other said get a 3600 CPU and a a different motherboard. I would like to add a few things go for a 3000/3200mhz kit of RAM you will save a few amount and a decent 550W PSU like Corsair CX 550W will be enough fir your system and see if you can afford a 1TB HDD as the games you wish to play take a lot of space like for eg. RDR2 recommend requirement is 150GB of space.
https://linustechtips.com/topic/1210029-help-on-my-first-build/
3 minutes ago, 5x5 said:
Get a 3600 and a B450 Pro4. When the board Costa the same as a CPU, that usually means the build is imbalanced price-wise
I agree with this. Otherwise looks like a solid build
PC
Ryzen 5 2600 Stock
Sapphire Nitro+ Special Edition Radeon RX580 8GB (Would Recommend)
Gigabyte B450M DS3H (Don't recommend)
Hyper 212 RGB Black Edition
Corsair Vengeance LPX 2x8GB DDR4 3000MHz CL15
Phanteks P300 (Would Recommend)
Kingston A400 240GB SSD
Seagate BarraCuda 1TB HDD
Corsair CX550M 550W  80+ Bronze
Deepcool FH-10 Fan Hub
3x BeQuiet Pure Wings 2
https://uk.pcpartpicker.com/user/marmour/saved/QTY3ZL
Peripherals
LG 24MK400H
Logitech G413 Carbon
Logitech G305 (AAA Adaptor - 10g reduction) (Would recommend)
Logitech Z150
HyperX Cloud II (Would recommend)
Moto G5 Plus (Webcam)
Phone
Pixel 3A XL (Would recommend)
*Useful Link* PSU Tier List: https://linustechtips.com/main/topic/1116640-psucultists-psu-tier-list/
https://linustechtips.com/topic/1210029-help-on-my-first-build/#findComment-13723426
System Specs:
  • CPU: AMD Ryzen 5 2600 @3.40ghz (6C/12T)
  • Motherboard: Asus Prime B450M-K
  • RAM: Corsair LPX 2*8GB DDR4 @3200mhz CL16
  • GPU: Zotac Nvidia GeForce RTX 2060 (TU-104 variant) 6GB GDDR6
  • Case: Antec GX202
  • Storage
  • SSD: WD 240GB,
    HDD: Toshiba 1 TB @7200rpm
  • PSU: Corsair CX550 (2017 grey unit)
  • Display(s): BenQ 22 inches monitor, 1080p @ 60hz
  • Cooling: 3 Antec case fans 120 mm (2 blue LED front intake and 1 non LED rear exhaust)
  • Sound: Behringer UMC22 USB Audio interface, AudioTechnica ATH M20x studio headphones
  • Operating System: Windows 10 Pro 64 bit.
https://linustechtips.com/topic/1210029-help-on-my-first-build/#findComment-13723509
