I have a motherboard that can handle 2400mhz of ram I want to upgrade to RGB 32gb ram that runs at 3600mhz if I put in the 3600mhz ram will my pc undserclock the ram to 2400mhz so it can run?
My Specs:
i7 7700
Motherboard: h110 plus
The RAM I wanna get
https://www.newegg.com/g-skill-32gb-288-pin-ddr4-sdram/p/N82E16820232920
https://linustechtips.com/topic/1208113-help/
H110 motherboards typically top out at either 2133 or 2400, so you won't be able to achieve 3600.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1208113-help/#findComment-13707771
Just now, slaapzz said:
ok so Im all good I can just plug in and play
It might also not be compatible, since the qualified vendor list for your board would certainly not have tested many high speed memory kits, and none that are nearly that high. Since it's newer, there's a chance it just won't boot.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1208113-help/#findComment-13707776
im not looking to run 3600mhz Im looking to run at 2400mhz I just want 32gb ram and RGB
https://linustechtips.com/topic/1208113-help/#findComment-13707779
Yes. The memory will post at the motherboard selected default Jedec profile, likely 2133.
The sticks you run now sound like the xmp and Jedec are the same thing therefor the board posts 2400 instead of 2133.... If that makes sense
https://linustechtips.com/topic/1208113-help/#findComment-13707784
ok good
https://linustechtips.com/topic/1208113-help/#findComment-13707785
Take heed to @Fasauceome advice as well however. Be sure to retain the option to return and exchange the memory from wherever you purchase from. ;)
Im so confused so will my motherboard be able to unclock the ram to 2400mhz yes or no all I want is 32gb ram and it to be rgb
https://linustechtips.com/topic/1208113-help/#findComment-13707798
what ever.......
https://linustechtips.com/topic/1208113-help/#findComment-13707809
