Hi,
I want to upgrade my pc to 32gb of RAM.
But I don't know if I should get 2 sticks of 16gb, or 4 sticks of 8 gb.
My PC specs
CPU - Intel Core i5-8600K
Motherboard - AsRock Z370 Extreme4
GPU - Gigabyte GeForce RTX 2080 Super Windforce OC 8G
I want to buy the G.Skill DDR4 Trident-Z but I am not shure if I will get 2 or 4 stick then.
What will be beter??
https://linustechtips.com/topic/1207715-will-there-be-a-diffrents/
Bandwidth wise
It's the same the only thing your gaining from 4 sticks is the extra capacity of your gonna use it
More pressure on the imc
If you are only gaming get the 2 stick kit
Phone: Pixel 3a (Purple-ish).
Build Log:
