Hi,
I currently have a Gigabyte Z370M D3H motherboard with Bios F13, and a an intel I3 8100.
I am looking at upgrading the CPU to the Intel I5 9600KF, This is on special currently and a 20% cheaper then the I5 9600K.
I know that the mobo can support the 9th gen cpu on the bios version i am running. But is there any issues with this upgrade or better options for that price point?
https://linustechtips.com/topic/1207334-cpu-upgrade-for-current-mobo/
Budget ?
County ?
Phone: Pixel 3a (Purple-ish).
Build Log:
I can't find it but how much does the 9700kf cost ?
If you can't afford it get a 9600kf or a 8700k
Build Log:
@TofuHaroto
I can only find the 9700K and its 615, so a bit of a jump to far on the budget.
https://www.umart.com.au/Intel-Core-i7-9700K-8-Core-LGA-1151-3-6GHz-CPU-Processor_47617G.html
Also does not look like they sell the 8700k. :(
so the 9600KF will have no problems running on the relevant mobo?
i would get an 8700k over a 9700kf/9600kf just because of the higher core count
ASTRAY NOIR
CPU
Ryzen 5 3600
Cooler
Corsair H100I PRO
RAM
PNY XLR-8 EPIC-X DDR4-3200 CL16 32GB
GPU
ASUS ROG RTX 2070
STORAGE
SAMSUNG 850 EVO, 2xSEAGATE BARRACUDA PRO 1TB,A2000 1TB
Case
NZXT H500
PSU
Enermax Revolution DF 650W
MONITOR
MSI MAG272,LG 22MP68BQ,DELL D2015H
PERIPHIRALS
Ducky One 2 (HORIZON) || Glorious Model O- Pink || G305 || Razer Nari Essential || HyperX Cloud II
If you can maybe look at the used market for an 8700k then get that
If it's overpriced get the 9600kf
Build Log:
8700k is def the best bet
ASTRAY NOIR
CPU
Ryzen 5 3600
Cooler
Corsair H100I PRO
RAM
GPU
ASUS ROG RTX 2070
STORAGE
Case
NZXT H500
PSU
MONITOR
PERIPHIRALS
