Running like its on Load
Go to solution Solved by SAV1OUR,
I blow some air into the dust filter land on fans about every twoo weeks, and I did it sunday. Its not the other fans, Its my gpu and Cpu fans
then just take you cpu and gpu fans out stilly  :P
Computer running loud and hot like its on load or something. Last night I fell asleep with it on, but only steam store was open. I got up and turned it off (or so I thought I did) but when I came home, it was on, and running loud. I'm leaving it off and its been about an hour? Is it just because it was on? Should I just wait. Not running really hot, just 2 degrees over usual (around 50 in my bios). Should I try to lower CPU fan RPM?
Any help would be great thanks guys
-BG
Gaming Rig "Project Primitus" - AMD FX-8320 CPU, Asus M5A97 R2.0 Mobo, G.Skill Sniper Series 8GB RAM @1866 MHz, WD Caviar Blue 1TB, Gigabyte Geforce GTX 760 GPU, Fractal Design Define R4 Window, Corsair CX600 PSU
Pics and my reviews for the build here - http://pcpartpicker.com/b/LvN
Peripherals - Corsair Vengeance K70 MX Red, Logitech G402,Kingston HyperX Cloud, 21" TV, Steelseries QcK Heavy Mousepad, Macbook Pro 2012 13"
https://linustechtips.com/topic/120674-running-like-its-on-load/
get a 212 evo or something the stock fans are always loud
Specs
https://linustechtips.com/topic/120674-running-like-its-on-load/#findComment-1607114
Nope louder than usual. It runs quiet usually even though it is loud on load
https://linustechtips.com/topic/120674-running-like-its-on-load/#findComment-1607121
maybe try removing all your fans and dusting them down?
Specs
https://linustechtips.com/topic/120674-running-like-its-on-load/#findComment-1607131
https://linustechtips.com/topic/120674-running-like-its-on-load/#findComment-1607154
Specs
https://linustechtips.com/topic/120674-running-like-its-on-load/#findComment-1607167
then just take you cpu and gpu fans out still :P
Yah its fine now. Took my gpu out because its less of a hassle first. Now running quitter and less hot. I have been planning to get like a dark rock 2 or h100i soon though
https://linustechtips.com/topic/120674-running-like-its-on-load/#findComment-1607203
