Zotac Temp Question
Solved by CrispyJakal,
Looking like a airflow issue, I did worry about the case as it has quite small intake slots on the side but i thought it might be enough, thanks for the help!
toxic_worper ·
Posted in New Builds and Planning6 -
3
1
voltigeurramon ·
Posted in Troubleshooting1 -
1
1
Vibora ·
Posted in New Builds and Planning5 -
5
3
Doctah ·
Posted in Peripherals3
