Question for Framerate Experts
By
sparkchomp
in PC Gaming
in PC Gaming
Solved by PlayStation 2,
The frame rate itself is fluctuating, but because the frame pacing seems to be consistent enough, it doesn't look all that jarring. Shadow of the Tomb Raider almost definitely uses a triple-buffered vertical-sync setup, which is why its frame rate can fluctuate without looking terrible or all stuttery.
smush ·
Posted in CPUs, Motherboards, and Memory2 -
asdasdasdasdasdasd ·
Posted in Hot Deals1 -
RipperDoc5456 ·
Posted in Troubleshooting2 -
Nebcs ·
1
FancyPants101 ·
