Problem on installing Intel XTU
Go to solution Solved by unclewebb,
Use ThrottleStop instead. It supports Intel's 8th Gen low power U series.
https://www.techpowerup.com/download/techpowerup-throttlestop/
Intel does not want to support their low power processors any more.
Even if you get XTU working, you will get better performance by using ThrottleStop.
https://i.imgur.com/eo0J744.png
So I was trying to install Intel XTU on my laptop (X509FJ-EJ125T).
And it always prompted "Attemped to install on a unsupported platform" and the error code is 0x80070643
I tried to look for solution on website, tried to download the older version, update BIOS, and it doesn't work at all.
Can someone help me?
https://gyazo.com/76931536dd55df16a23bc05fbbfe0493
https://linustechtips.com/topic/1205052-problem-on-installing-intel-xtu/
What laptop do you have?
You can't oc a locked sku cpu
You do know that correct ?
Phone: Pixel 3a (Purple-ish).
Build Log:
My laptop is X509FJ-EJ125T
I'm aware of that but I see on some forums people successfully install it while it showing this error code by using older version of XTU.
But it didn't work for me tbh.
Thx bro, it worked.
