120mm fans in NZXT H510
Jelee229
Hey guys,
i was wondering how many fans I can fit inside the nzxt h510. I’m going to use 120mm fans w/ rgb :/
thanks
Four. Two in the front on the bracket that comes out, one in the top and one in the back. The top also supports a 140mm fan so you could do that instead of the 120mm.
Main Rig: CPU: AMD Ryzen 7 5800X | RAM: 32GB (2x16GB) KLEVV CRAS XR RGB DDR4-3600 | Motherboard: Gigabyte B550I AORUS PRO AX | Storage: 512GB SKHynix PC401, 1TB Samsung 970 EVO Plus, 2x Micron 1100 256GB SATA SSDs | GPU: EVGA RTX 3080 FTW3 Ultra 10GB | Cooling: ThermalTake Floe 280mm w/ be quiet! Pure Wings 3 | Case: Sliger SM580 (Black) | PSU: Lian Li SP 850W
Server: CPU: AMD Ryzen 3 3100 | RAM: 32GB (2x16GB) Crucial DDR4 Pro | Motherboard: ASUS PRIME B550-PLUS AC-HES | Storage: 128GB Samsung PM961, 4TB Seagate IronWolf | GPU: AMD FirePro WX 3100 | Cooling: EK-AIO Elite 360 D-RGB | Case: Corsair 5000D Airflow (White) | PSU: Seasonic Focus GM-850
Miscellaneous: Dell Optiplex 7060 Micro (i5-8500T/16GB/512GB), Lenovo ThinkCentre M715q Tiny (R5 2400GE/16GB/256GB), Dell Optiplex 7040 SFF (i5-6400/8GB/128GB)
29 minutes ago, Jelee229 said:
Hey guys,
thanks
Like the maximum that can be stuffed in without regard to whether or not they are useful for you?
14 minutes ago, youngboy said:
I really like this case. NZXT H510. One of my favorite cases. Unfortunately, it only supports 4 fans. Here is what NZXT says:
Front: 2 x 120/2 x 140mm (1 Aer F120 Case Version included) Top: 1 x 120/1 x 140mm Rear: 1 x 120 (1 Aer F 120 Case Version included)
Only 4 120mm fans supported on this. If you can, use 140mm fans, because they provide for airflow due to their larger size
Less static pressure though.  It’s often a worthwhile trade off but not always.
No, I’m looking for how many will fit in the case, but also how many I need for optimal airflow
Then you need to test.  Airflow is hydrodynamics which is so fearsomely complicated it’s difficult to predict in anything but the roughest way.  Not a fast thing to do.  The more fans the more noise and usually he more airflow but not always.  You’ll want to pay attention to both you cpu and gpu heat.
Ok, thanks
