Hi guys
I'm writing from Italy, I need your help to squeeze my build a little:
i have:
x570 aorus master
2x8 gb gskill 4266 cl19
ryzen 7 3700x
nvidia 1070 by evga
I set my ram as you see in the picture but I have a problem: the memtest lasted about 40 minutes did not reveal any errors but some times the pc does not turn on, goes into bootloop and after resetting the bios (it does it by itself after 2-3 boot attempts)  it starts all over but resetting the bios in its entirety 😰
have any of you had such problems with these motherboards? the bios I have now is F11, the latest available on the site
https://linustechtips.com/topic/1203202-x570-aorus-master-problems/
Try updating the bios  if it's a ram problem
Try with one stick at a time
Phone: Pixel 3a (Purple-ish).
Build Log:
even if they were RAM, why don't I have any problems in the game or during normal use and not even a report on memtest? but only problems at startup? then in your opinion for those ram (4266 cl19 1.4v) the latencies calculated by dram calculator can already give instability?
ps: the bios is the last on aorus website
28 minutes ago, narrdarr said:
I notice the calculator is for 3733mhz.
Is your ram decoupled from from the fabric?
i put 3733 because it is the result that I wanted to get to have it the same with the infinity fabric,I bought these rams thinking I could bring them to lower frequency (everyone says the best on ryzen is 3733) but with better latencies am I wrong?
I noticed one thing:
cinebench r20 totaly stock (not even activated xmp profile) 4590
Cinebench r20 with ram at 3733 with the frequencies on the screen 4953
cinebench r20 with ram in xmp 4994
Well it could be not stable in situations like boot ups were the ram probably has to do the most job and that brings the best out of it
It could be the imc
Build Log:
4 minutes ago, tsk_force said:
IMC? How can i fix It?
Try booting to the bios
Set the soc voltage to 1.1
And check if that helps
If you have ant overclock on your cpu get rid of it
It could be the Interconnect acting up
Build Log:
the cpu is stock, i have not even installed amd overdrive, i would like to make the memories part stable at 101% otherwise i am going crazy to understand where the crashes come from
the values pulled out by dram calculator how do you see them? can they go or is there something to correct? I have very little experience with amd and ryzen 🤦🏾‍♂️
