best obs settings
Go to solution Solved by AlexOak,
Gpu Based
  1. H.265 codec For 4k and up (No improvement in 1080p but you can try it. Don't know if amd has one)
  2. H.264 codec For 1080p and below
  3. 30,000~50,000 kbps CBR
CPU
  1. x264 codec
  2. fast ~ medium
  3. 10,000~30,000 CBR (Play around with this. This will increase cpu usage)
x265 is heavy on the cpu, so it was not an option unless you have a second PC set-up
i've been wanting to record some gameplay with obs but i just cant find the right balance between quality and file size
does anyone have any experience with obs to help?
my specs are: ryzen 7 2700, rx 5700xt and 32gb of ram so i can go with cpu encoding
(btw im playing in 4k and i want the output to be 1080p 30fps)
gaming system: Intel core I9 12900ks / biostar Z690A valkyrie / 4x8gb corsair Vengeance @3333Mhz ram / RX 7900XTX pulse gpu / Thermalright peerless assassin 140 /Coolermaster Qube 500 case / Be Quiet Dark Power Pro 12 1500w power supply
laptop: Dell xps 9510, 3.5k OLED, i7 11800h, rtx 3050 ti, 2x16gb DDR4 @ 3200Mhz, 1TB main drive, 2TB add in ssd
https://linustechtips.com/topic/1203181-best-obs-settings/
Gpu Based
CPU
  1. x264 codec
  2. fast ~ medium
https://linustechtips.com/topic/1203181-best-obs-settings/#findComment-13667494
