https://linustechtips.com/topic/1203170-first-pc-build/
Corsair cx 450 / 550 (grey label)  will be fine for system if you want to go top tier the seasonic 550 Focus gx is also a great choice (difference in the USA between these two is 28 bucks which I think in that case I’d rather pick seasonic but all up to your budget)
https://linustechtips.com/topic/1203170-first-pc-build/#findComment-13667431
Thanks for the replies, I have 2 to choose from one is semi modular but the other is not? The semi modular one is cheaper?
Corsair CP-9020120-UK CX Series 450 W CX450 ATX/EPS 80 PLUS Bronze Power Supply Unit - Black https://www.amazon.co.uk/dp/B06WW51XBX/ref=cm_sw_r_other_apa_i_KMv1EbY688KRF
Corsair CP-9020101-UK CX450M 450 W 80+ Bronze Certified ATX Power Supply Unit https://www.amazon.co.uk/dp/B01C3FFOHS/ref=cm_sw_r_other_apa_i_gNv1EbENX6J6B
Do you know what the difference is?
Also found this one, is it any good?
EVGA 450W ATX Power Supply - BR Series - (Active PFC/80 PLUS Bronze) https://www.amazon.co.uk/dp/B07FLLB9N8/ref=cm_sw_r_other_apa_i_jOv1EbPSPKWHN
Thanks,
https://linustechtips.com/topic/1203170-first-pc-build/#findComment-13668168
Thanks,
The cx is better, if you can stuff all the extra cables behind the case then I would say get that one, Shame your case doesn’t have a psu shroud would make it a no brainer. Br is worse then both of those as far as I know.
https://linustechtips.com/topic/1203170-first-pc-build/#findComment-13669563
