First of all welcome to the forums
Second of all check your temps
Try ddu
Enable xmp/ dcop (it probably won't increase your performance as much as an AMD based system but it will still increase it )
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1203104-low-fps/#findComment-13666847
12 minutes ago, Yunuziy said:
1440p 100%res graphics set to low/ very low and disabled xmp enabled temps about 60 to 70 f. I am pretty new to pc as well
Don't forget to quote us so we can see your reply.
Have you instaleed the motherboard/gpu drivers?
enable xmp in the bios, it should raise the fps a small bit.
https://linustechtips.com/topic/1203104-low-fps/#findComment-13667010
Ddu your drivers and enable xmp/dcop
Build Log:
https://linustechtips.com/topic/1203104-low-fps/#findComment-13667013
Sorry about and I have only done the gpu updates when it comes out that’s it
https://linustechtips.com/topic/1203104-low-fps/#findComment-13667058
Enable xmp / dcop
Build Log:
https://linustechtips.com/topic/1203104-low-fps/#findComment-13667072
That is weird that you are getting that low of FPS with your setup and those settings. Like others suggest I would recommend wiping clean your drivers via DDU and download 442.74 drivers as I find these are the best ones right now for CoD in terms of performance. Also XMP/DOCP can be a hit or miss in terms of CoD crashing because of it. Sometimes I can't play CoD with mine enabled but other times it runs just fine.
https://linustechtips.com/topic/1203104-low-fps/#findComment-13667256
So my pc came with a 2070 and I upgraded to a 2080 super could that be an issue that I didn’t do something
https://linustechtips.com/topic/1203104-low-fps/#findComment-13667739
Enable
Xmp
Dcop
Build Log:
https://linustechtips.com/topic/1203104-low-fps/#findComment-13667743
