psu Loud PSU fan noise after replacing GPU
Solved by CristianJaviM,
Thanks you for your reply!
Yes, that was my first course of action, dusting the fan part of the PSU, but to no avail. I forgot to mention that sometimes, very occasionally, there was a rattling noise and it came from the PSU as well.
Since I looked for answers for my question all over the web, a bunch of helpful guys (chiefly Jon Gerow from Jonnyguru) pointed me out to the best option to replace my PSU and I did: I went with a Corsair CX650 due to it's decent rating for a midrange machine and LLC topology and DC to DC feature that, as I was told, was a pretty good option considering it's a budget PSU.
Thanks you all for the help!
