It depends on the games and settings you are going to be running. If you're gaming at 4k you will have a much heavier load on the GPU than if you are doing 1080p high refresh. Also different games put more or less stress on the CPU or GPU depending on the way the game is programmed. There could also be a bottleneck somewhere else in the system, like memory. It really all depends on what your system is being used for.
