Hi there!
I really would like to start programming, unfortunately my school doesn't teach it. -_-
Does any know of a way I could learn the basics or even teach me themselves. I'm only 15 so i don't have much money. What I need is a cheap but challenging project to get me started :)
thanks for your time :D
Ross
https://linustechtips.com/topic/12025-help-for-a-noob/
Which language? A good place to start would be on YouTube, this guy has great tutorials: https://www.youtube.com/user/thenewboston
Most local libraries also have pretty books that will help you.
thanks for the really fast reply! I love this forum!
I'm thinking PIC or python right now, I'll definitely have a look at that YouTube channel in more detail :)
https://linustechtips.com/topic/12025-help-for-a-noob/#findComment-128300
Python is fun :D and yeah just youtube it if you know nothing. Maybe check out a book thats not like a long boring one but one by the author O'Reilly.
The books they release are kinda like reference books to look something up real quick like a rule or how to do something but I feel like something kinda more vague and less boiler plate would help anyone get a general idea of how things are done!
Hope that helps!
https://linustechtips.com/topic/12025-help-for-a-noob/#findComment-128341
i'd look at C/C++ too, alot of languages are derived from it and it's quite important.
AMD 8350 // 8 GB Corsair Ram // PNY 780 Ti // Asus 1080p Monitor // Antec 120mm AIO // CM Quickfire TK w/ Custom Caps  // RAT 5 mouse // Audio Technica m50x // Behringer 4-line + Line6 8-line Audio Interfaces
https://linustechtips.com/topic/12025-help-for-a-noob/#findComment-135671
I would suggest the usual beginning resource for learning Python, which is here:
 http://learnpythonthehardway.org/book/
So naturally, I would suggest Python if you're looking at getting started. As for a project, Python can do a lot of things. It depends what you're into but maybe you can try and start simple with the Fibonacci numbers and go from there.
https://linustechtips.com/topic/12025-help-for-a-noob/#findComment-141467
When I started programming I tried to solve some common task by programming them, for example, moving my default library folders every time i reinstall windows, or maybe a database of movies or games. Dont think it too much, just simple tasks to make you life easier, you will learn the basics, and also feel that you made something that is actually usefull for you.
Mobo: Asus Maximus Impact VI Processor: Intel 4690K @ 4.4Ghz 1.22Vlts Memory: 2x8 GB DDR3 1866Mhz GSkill Sniper
VGA: Sapphire HD 7970 3GB OC Audio: Asus Impact Supreme FX SSD: Mushkin Chronos 120GB HDD: WD Black 500GB
Power Supply: Coolermaster V650 Semi Modular Case: Bitfenix Prodigy Cooling: Corsair H100i
https://linustechtips.com/topic/12025-help-for-a-noob/#findComment-141566
