Budget (including currency): about where it is at currently though I would like to maybe drop the budget a little if possible
Country: 'MERICA
Games, programs or workloads that it will be used for: Minecraft, Roblox, and CS: GO... those are the main games and the others will probs be small emulators and platformers.
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): I am probably going to purchase everything in mid-late July... (still saving, about 1/2 way to my budget)... I am trying to get an entry level pc...
My main questions, do I need a better GPU? Is there a cheaper but about the same quality monitor screen? Should I go for more storage? I think the case only comes with one fan... should I buy another? What would be a good/cheapish option?
Oof... this is my like 5th post about planning... I keep finding better or cheaper options... I think I am addicted...
Sorry if my questions are a little stupid... I am living in the BGPC era (Before the Gaming PC)
Light users can't read this. Good job for using Night Theme!
https://linustechtips.com/topic/1202006-thoughts-again/
3 minutes ago, Doggo lover said:
can i suggest the asus tuf b450m-plus gaming it is a good mobo for the price.
No you can't suggest that board...
jk, ur fine
I looked at that board earlier and wondered it's quality as it is pretty cheap in price...
https://linustechtips.com/topic/1202006-thoughts-again/#findComment-13658357
jk, ur fine
its pretty good i mean its asus what can i say. it also has rgb support so that is a bonus. i have it in my rig and it is pretty great for the price.
https://linustechtips.com/topic/1202006-thoughts-again/#findComment-13658359
Something like this would be much better...
PCPartPicker Part List
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor  ($167.00 @ Amazon)
Motherboard: ASRock B450M Steel Legend Micro ATX AM4 Motherboard  ($94.99 @ Newegg)
Memory: G.Skill Aegis 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  ($59.99 @ Newegg)
Storage: Silicon Power A80 1 TB M.2-2280 NVME Solid State Drive  ($132.99 @ Amazon)
Video Card: MSI Radeon RX 5700 8 GB MECH OC Video Card  ($303.98 @ Newegg)
Case: Deepcool MATREXX 30 MicroATX Mini Tower Case  ($42.98 @ Newegg)
Power Supply: Cooler Master MWE Gold 650 W 80+ Gold Certified Fully Modular ATX Power Supply  ($99.99 @ Best Buy)
Monitor: VIOTEK GN27D 27.0" 2560x1440 144 Hz Monitor  ($269.99 @ Best Buy)
Keyboard: Redragon K512 SHIVA RGB Wired Gaming Keyboard  ($36.99 @ Amazon)
Mouse: Redragon M602 Wired Optical Mouse  ($22.99 @ Amazon)
Total: $1231.89
Generated by PCPartPicker 2020-05-29 19:36 EDT-0400
SSD TIER LIST
CPU - Ryzen 7 3700X
Mobo - ASRock X470 Taichi
Memory - G.Skill Trident Z RGB (8x2 3200MHz)
Storage - Sabrent Rocket 1TB - Seagate Barracuda 2TBWD Black 1TB
GPU - MSI GeForce GTX 980Ti LIGHTNING
CaseFractal Design Meshify C
PSUSuper Flower Leadex II Gold 650W
https://linustechtips.com/topic/1202006-thoughts-again/#findComment-13658452
