So I was having some issues with Java so decided to uninstall and reinstall, but now as the fresh install ends it has the following error: "Error: Could Not Create The Java Virtual Machine, a fatal exception has occurred. Program will exit.". I have been searching for fixes for a while, and have tried Adding the _JAVA_OPTIONS to System Variables and Opening java.exe with admin rights.
Any other fixes or something I've missed?
Thanks.
What are you doing with java? Running an applet/program or programming in java? If the latter you need to reinstall Java SE after reinstalling the JRE
Also when making changes to environment variables you may need logout/restart pc for changes to apply,
Just trying to run programs in Java, and yeah I've restarted my PC after changing environment variables,
