Case fan configuration
Go to solution Solved by Entropy.,
No. To fight each other they would need to be configured so one draws in air and one pushed out (oppositely configured) but this isn't. It won't give (much) of a boost over one fan, but It works.
I am NOT a professional and a lot of the time what I'm saying is based on limited knowledge and experience. I'm going to be incorrect at times.
Motherboard Tier List                   How many watts do I need?
Best B550 Motherboards             Best Intel Z490 Motherboards
PC Troubleshooting                      You don't need a big PSU
PSU Tier List                                Common pc building mistakes
PC BUILD Guide! (POV)              How to Overclock your CPU
https://linustechtips.com/topic/1201535-case-fan-configuration/#findComment-13654528
1 minute ago, Hz Eurythmic said:
Do the fans on the GPU cooler exhaust? Because if they do, the fans on the bottom exhaust as well.
the gpu cooler fans need to intake air from the space between the bottom and the card itself. you have fans on the bottom stealing the intake air from the card
https://linustechtips.com/topic/1201535-case-fan-configuration/#findComment-13654668
