heya,
so i just cleaned out my computer after 3 years, since the first tme i built it, and i am literally shocked beyond disbelief at the results. i used to run overwatch at around 90 degrees after playing for around 20 mins or so and after cleaning out everything with compressed air i float around at 50 degrees after the same amount of time playing. i didn't benchmark it before properly, though i used aida64 post cleaning to stress fpu, cache, cpu and memory and maxed out at around 65 degrees, which i'd assume would be much higher than the 90 on overwatch pre cleaning. anyway i just wanted to show off my 40 degree drop in cpu temps since none of my other friends are into computers. hopefully this is the right category, first post in like 2 years as well, thank u 4 reading.
QUOTE ME FOR A REPLY.
CPU - Ryzen 5 1600  CPU Cooler - Wraith Spire  Motherboard -  ASRock AB350M Pro4  RAM - G.Skill Ripjaws 4 series (2x4) DDR4-2400  Graphics Card - Asus STRIX GTX 950 (upgrade in future)  Power Supply - Corsair CXM 450W 80+ Bronze  Storage - WD Blue 1TB | PNY 120GB 2.5" SSD  Case - Fractal Design Core 2300
"Sometimes you must hurt in order to know, fall in order to grow and lose in order to gain, because life’s greatest lessons are learnt through pain.
https://linustechtips.com/topic/1201475-cpu-temps/
