I have a custom built system that keeps on failing when I go past the BIOS. I first started out with a MSI X570 A-Pro Motherboard which allowed me to boot into Bios, and even run a memtest86+ without a problem. As soon as I get past the BIOS and try to install an OS with will fail after a minute or so. I get the debug lights flashing between CPU and DRAM.
These are the things I tried.
  1. Checked the pins on the CPU if they are bent
  2. I tried using different memory slots with just one memory module.
  3. Changed Power supplies
  4. Tried to install both Windows and Ubuntu
  5. I thought it was a bad motherboard so I replaced it with a B450 Aorus Pro WiFi (Rev 1.0 )
Build List:
CPU: AMD Ryzen 7 2700X
RAM: Corsair Vengeance LPX 16GB (2 X 8GB) DDR4 32000
Mobo: B450 Aorus Pro Wifi (Rev 1.0)
HDD: Samsung 970 Evo Plus 500 GB
Graphics: ATI Radeon 256MB PCI-E 7120036200G Video Graphics Card Cedar (test)
Case: Fractal Design Focus G
PSU: Corsair RM850X
**UPDATE
I replaced it with a 3000G CPU and everything is working well. I just RMA'd the 2700X
Edited by sjabini
https://linustechtips.com/topic/1201379-flashing-between-dram-and-cpu/
what was the original gpu ?
try 1 stick at a time and try different modules
Phone: Pixel 3a (Purple-ish).
Build Log:
I have a similar issue except when im using my PC it randomly grey screens and i get DRAM and CPU lights alternating. I still have no fix for it. I re-updated my CPU driver and that fixed it for a week then it came back so maybe try that.
CPU: AMD Ryzen 5 2600
RAM: G Skill 16GB (2 X 8GB) DDR4 32000
Mobo: B450 Aorus M (Rev 1.0)
Graphics: MSI Radeon Rx 570
PSU: EVGA 650 BQ Bronze
first of all
welcome to the forums
second of all
if you dont have anything that might fix this or you have the same problem
just please make your own thread
Build Log:
I tried using one module at a time. I've only tried one other memory module.
The original graphics card was a MSI GTX 760.
does it work with the kepler card ?
Build Log:
  • 2 weeks later...
