Your motherboard is crappy cheap one. Your video card drain power from PCI-e and has no external power plug.
It's not something that should happens, but it happens sometimes. Your videocard is not compatible with your motherboard, even if should work in theory.
In worst case - you just bricked your motherboard.
https://linustechtips.com/topic/1200653-i-need-help-guys/#findComment-13648385
aff fuck and i can run with my new video card
https://linustechtips.com/topic/1200653-i-need-help-guys/#findComment-13648394
