Hi,
ive just built a new pc, Tuf b450m gaming motherboard, Ryzen 3600, gtx 1070, 16gb corsair vengeance  2400mhz ram, 128gb ssd which has windows 10 installed on it, 1tb hard drive and a Corsair 450w 80 plus bronze power supply in a Corsair carbide 275r Case and im pretty sure I’ve installed everything correctly, I checked the compatibility multiple times before purchasing the parts and everything was compatible, everything powers on I can see all the parts are working but I cannot get the pc to detect the display I’ve tried 2 different displays using HDMI and Display Port. Does anyone know why this could be, it may be something very simple that I’m missing
https://linustechtips.com/topic/1200589-new-build-help-please/
does the PC make any sound? like beeping or has something like an led that glows with words on its side?
Im with the mentaility of "IF IM NOT SURE IF ITS ENOUGH COOLING, GO OVERKILL"
CURRENT PC SPECS
CPU             Ryzen 5 3600 (Formerly Ryzen 3 1200)
GPU             : ASUS RX 580 Dual OC (Formerly ASUS GTX 1060 but it got corroded for some odd reasons)
GPU COOOER      : ID Cooling Frostflow 120 VGA (Stock cooler overheats even when undervolted :()
MOBO            : MSI B350m Bazooka
MEMORY          Team Group Elite TUF DDR4 3600 Mhz CL 16
STORAGE         : Seagate Baracudda 1TB and Kingston SSD
PSU             : Thermaltake Lite power 550W (Gonna change soon as i dont trust this)
CASE            : Rakk Anyag Frost
CPU COOLER      : ID-Cooling SE 207
CASE FANS       : Mix of ID cooling fans, Corsair fans and Rakk Ounos (planned change to ID Cooling)
DISPLAY         : SpectrePro XTNS24 144hz Curved VA panel
MOUSE           : Logitech G603 Lightspeed
KEYBOARD        : Rakk Lam Ang
HEADSET         : Plantronics RIG 500HD
Kingston Hyper X Stinger
and a whole lot of LED everywhere(behind the monitor, behind the desk, behind the shelf of the PC mount and inside the case)
https://linustechtips.com/topic/1200589-new-build-help-please/#findComment-13647848
No beeps and all leds are lit up, I have read online to attach a speaker and listen for the beeps to see if there’s an issue
https://linustechtips.com/topic/1200589-new-build-help-please/#findComment-13647877
is there something like an LED on the board like EZ debug led?
CURRENT PC SPECS
https://linustechtips.com/topic/1200589-new-build-help-please/#findComment-13647884
try to reseat the GPU. it could have been a mis seated GPU.
CURRENT PC SPECS
https://linustechtips.com/topic/1200589-new-build-help-please/#findComment-13647906
I have tried taking the gpu out and putting it back in twice so i don’t think I have mis seated it but will try that again and also tried using the HDMI on the motherboard, which is why I’m lead to believe its not the graphics card
https://linustechtips.com/topic/1200589-new-build-help-please/#findComment-13647921
what is the exact model of the motherboard? because at this point that i have no idea what kind of error due to lack of speaker. thus the model of the motherboard might help
CURRENT PC SPECS
https://linustechtips.com/topic/1200589-new-build-help-please/#findComment-13647928
ASUS TUF B450m plus gaming motherboard
https://linustechtips.com/topic/1200589-new-build-help-please/#findComment-13647938
did you happen to update the bios before installing the CPU? or is it updated to the latest bios? according to the motherboard, it only supports 1st and 2nd gen out of the box. if that's the case, that might be the reason my friend.
CURRENT PC SPECS
https://linustechtips.com/topic/1200589-new-build-help-please/#findComment-13647945
Ah right unfortunately I didn’t do that how would I go about doing that now?
https://linustechtips.com/topic/1200589-new-build-help-please/#findComment-13647970
no wait. it depends. the site actually mentions that it supports the 3rd gen. unless its the older model.
CURRENT PC SPECS
https://linustechtips.com/topic/1200589-new-build-help-please/#findComment-13647980
That’s what has confused me mostly about all this, I’ve seen from multiple different sources that it should work as it says supports ryzen 3000. I’ve only just purchased it recently brand new so I would assume it’s a newer model.
if I download the new bios update onto a usb stock and then plugged that in to my new pc do you think that would allow me to update the bios?
https://linustechtips.com/topic/1200589-new-build-help-please/#findComment-13647989
im not really sure. as far as i know, you will need an older AM4 CPU for it to work. though i hope someone else from the community can help since at this point, i have no idea what to help.
CURRENT PC SPECS
https://linustechtips.com/topic/1200589-new-build-help-please/#findComment-13647991
Ok thank you so much for your help
https://linustechtips.com/topic/1200589-new-build-help-please/#findComment-13647993
Just discovered that it shouldn’t need a bios update as in box of the cpu there was a little leaflet saying “ motherboards with amd ryzen 3000 desktop ready label on the box Are compatible without requiring a bios update” which the motherboard box has this on it so back to square 1 I guess just going to have to check all connections 1000 times
https://linustechtips.com/topic/1200589-new-build-help-please/#findComment-13648103
well. oof. at that point then, try to run with just one of the ram sticks as a trial and error. try to put it in one of the slots one at a time.
CURRENT PC SPECS
https://linustechtips.com/topic/1200589-new-build-help-please/#findComment-13648110
