Budget (including currency): Unknown
Country: United States
Games, programs or workloads that it will be used for: Basic Photo/Video editing
Hello,
So I am currently planning a build that involves an iMac G3. I want to retrofit a modern hackintosh inside and want to mount an lcd panel to replace the screen that is installed. My plan is to use a 13inch 16:9 screen and add bezels on the side. The issue I am running into while planning it out is powering the screen. I found a few LCD panels that can fit as well as control boards with HDMI out. These control boards require a DC 12V connection to power the screen. I am aware the 6 pin connector on a power supply can supply 12V and was wondering how likely as well as difficult it would be to rig this up. I have no electrical background what so ever. I know it would be easier to run a 2nd power cable out of the back of the system to power the monitor but I would like to make the computer as minimum as possible with the exception of being able to connect a 2nd screen (because come on, 13 inches isn't enough). Is this plan far fetched or do I have the right idea on how to achieve this.
Control Board - https://www.ebay.com/itm/For-LP133WF4-1920X1080-EDP-Screen-LCD-LED-HDMI-VGA-controller-board-DIY-kit/163224891699?hash=item2600f63133:m:mcO81ChL-ToxuaZrPdmnZOQ&autorefresh=true
LCD Panel - https://www.ebay.com/itm/13-3-IPS-LCD-Display-Screen-LP133WF4-SPB1-for-Lenovo-Ideapad-710S-1080P-30pins/202515551015?_trkparms=ispr%3D1&hash=item2f26de1327:g:OVwAAOSwPEhcf2nD&enc=AQAEAAACYIQvEcHUrT7nmUC3yY5qbPyaBN1nJEDYW8MyypsJPgXKxIntehGqQQl8nLx%2FEZs3RgioO0JxRNPl0aEhWcYdYNcamRgpiFHfEU%2F%2FGNLQhfYwX0eGUeK4ENfdDDHJ44xg%2FNFJSqBRSQYm%2FJvjrv8Fo%2FRTC2s74%2BZk9FSmCGINxNdtE6hteC7aoI6QU7Kst%2BmzdRnoSgZdn032TLjYBG0d6uhLaA3S5754Sod6YJV0dKMiRB6XsL4Cam0zNV5b9A0dZh0g4EUVcH2jy8nWj5zRN4ug%2FX9dGbmP1UB6fHKgzPhcjKjqeHYkBZmzYr5Bq4uVYv5cWrcl377YeWiYwqm6pwffrPyCXZqsj1M2aWETACjzJ510vs9M0%2BSYU8sbK5pMOTvyf2ReAxPgBckC54KWOGaTXlr5eR9%2FzGJW4RlQ%2BuzmFz0pKz1jKm%2FdjncCym0a4ovSgmiZLVNfXdEfqnvZAJPkr4qmNfsT3Z1dcKmpOlpPV334CIQyet%2BT%2Fn3zhS4l0kl4NDvARNOD%2BIonuXU9L%2FAfg9zLBWw0EOPoNcsLc0j10NzBo136xAIDD0FOy8k0vq3q64OaxyS%2F7eCak2sVr5vbnXamRCjngPdhcyCW2X6ThSp%2FQZZCi3a31JYV33Wrpnp2DfS3KJqG98smZFmJs9OjFOCQNa5L83Okdu3JVUFBpLevnWV8iKtk5m4S9xK9ZwLagxyKpHcJiGKQWpngf7g6xTZqaj6Bu2VU6MzRgNjCUXScYZ%2BRvqyh%2FOKBX6rrUh4RFtkwtmSYPkcX%2BD9z%2Fl6tij%2BlLIQpLMU1uHES4oeW&checksum=2025155510156c474662d03342598810a85ab516f189
https://linustechtips.com/topic/1200570-lcd-power-question/
1 minute ago, RobinD said:
I wonder if the chips used in this build would help, could use it to power the screen with a usb c port?
I've seen this, however I want to avoid using ports on the motherboard. Since I will need to use a MINI ITX board, expansion is kind of limited. Worse case this is a good option though.
https://linustechtips.com/topic/1200570-lcd-power-question/#findComment-13647723
https://linustechtips.com/topic/1200570-lcd-power-question/#findComment-13647745
5 minutes ago, RobinD said:
I didn't even think of molex! I try to block it out of memory honestly. That might be an idea.
https://linustechtips.com/topic/1200570-lcd-power-question/#findComment-13647761
