I think my memory (Model: 2x Samsung M378A2K43BB1-CRC) might be underperforming a bit, but I don't know why that would be the case. I have attached the aida64 result and the timings from ryzen dram calculator.
I am getting just below 47000mb/s in read performance, while I have seen a lot of people getting higher speeds (~53000mb/s) at lower memclocks.
Thanks in advance.
Intel i9-7960X || ASUS WS X299 PRO || INNO3D RTX 2080 TI || 4x16 GB Samsung DDR4 || MasterCase SL600M
https://linustechtips.com/topic/1199925-sub-par-memory-performance/
Your AIDA64 is outdated
Desktop benching:
but the main part, aka the bench dll isn't.
Also I fixed the issue, the IF clock was automatically set to 900mhz, so I had to set it 1800mhz manually and now it's fine.
I have seen the app version itself affect the same bench.dll's scoring
Hmm I thought it will keep FCLK to half of data rate up till 3600MHz memory?
Desktop benching:
Same. Maybe this is an asrock exclusive quirk. But it works fine now so I don't really care.
