So I'm having this problem where my screen will freeze with whatever is on it and the audio will loop the past half a second or so. This has happened 3 times, while playing a game once and two times when I was simply web browsing. First time it happened when the pc was on for 24+ hours another after around 3-4 hours and the last time it happened was after just ten minutes. When I try rebooting right after the problem occurred, it seems like random luck if I actually get any screen output. The motherboard powers up, fans come on, but no output. However the problem hasnt happened since and the pc has been on for around 24 hours
I've had this system with the same hardware for almost a year and it has run fine until last week when it seemed like my m.2 SATA boot ssd failed. So now I'm using a regular SATA ssd for windows and the problem I have described above has been happening
PC Specs:
Ryzen 3 2200g
ASROCK B450M Pro 4
Radeon RX 570
Corsair 3200mhz 2x8gb ram
WD Green 480gb ssd
Thermaltake Smart 500W
Crucial MX500 (drive that suspected to fail)
https://linustechtips.com/topic/1199757-im-having-a-weird-pc-issue/
