I suddenly got this problem on my pc
when I power on it
it boots up but there's an underscore blinking on the upper left of black screen
& this is the worst part, when i plug in any usb mouse or keyboard or flash drive it freezes on gigabyte logo but it boots when i use ps/2 k&m port & yes still black screen with underscore blinking
things i did after this happened
1.clr_cmos
still black screen
2.replaced ram sticks with backups
still black screen
3.used other hdd with working W10
still black screen
My pc parts
Case: Acrylic mid tower
Motherboard: Gigabyte GA-990FXA-UD3 3.0
CPU:FX-8320 8core.
Cooler:Cooler Master Seidon 120V
RAM: 2x4GB Kingston & 2x4GB Kingmax
GPU:Sapphire HD6570 4GB
PSU:Cooler Master 650v 80+Gold semi-modular
https://linustechtips.com/topic/1199723-boot-problems-with-pc/
24 minutes ago, Not Wills said:
boot media with the bios and motherboard, try reset the cmos, if that doesnt work, i think you will need a new motherboard
I already did reset the cmos
but still the same
so basically my motherboard is unusable or dead now
I guess I'll have to check prices of these two motherboards
Gigabyte 990FX-Gaming 1.1
Asus TUF sabertooth 990fx r3.0
https://linustechtips.com/topic/1199723-boot-problems-with-pc/#findComment-13642220
