You could justify getting the Athlon with the excuse that you'll upgrade to a Phenom II X6 later in time, but you'd also have to mind the power supply that you're getting with the rig because those CPUs are very power hungry.
Not considering upgrades, a quad core CPU vs a dual core CPU from that era comes out way in favor of the quad core, bar none.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1198833-small-pc-help/#findComment-13634868
Then my other question would be, which "cheap" cpu do you recommend (amd) and if possible, with which motherboard do you recommend it. Ty for your answer
https://linustechtips.com/topic/1198833-small-pc-help/#findComment-13635236
Cheap is relative, and it really depends on what this CPU is being used for. Although, when looking at older CPUs, specifically around this era, early core i3 and i5 models are usually much better choices all around, so look for dual and quad cores for LGA 1156, and whatever cheap motherboard you can get.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1198833-small-pc-help/#findComment-13635277
Forgot to mention, I want it for gaming (wanting a config for overwatch mostly)
https://linustechtips.com/topic/1198833-small-pc-help/#findComment-13635306
