2 minutes ago, Electronics Wizardy said:
How many gpus do you want?
Gpu mining seems to have pretty much died.
Do you have a budget?
Do you want to use risers?
1. I want to be able to use up to 4 GPUs
2. I do not have a budget for the motherboard
3. Yes I would be ok with using risers.
https://linustechtips.com/topic/1198418-motherboard-help/#findComment-13632093
Lots of gpus meet those needs, but something like this is a common pick https://pcpartpicker.com/product/jcYQzy/msi-b450-tomahawk-max-atx-am4-motherboard-b450-tomahawk-max
https://linustechtips.com/topic/1198418-motherboard-help/#findComment-13632100
Will all PCIe ports be compatible with a ryzen 7 3800x?
https://linustechtips.com/topic/1198418-motherboard-help/#findComment-13632126
1 minute ago, AB44400 said:
Thanks! This is my setup so far, do you think it will work well?
  • Ps. the high watt psu is incase i do mining
Id probalby get a nvme drive, slightly faster, about the same price, so might as well.
Do you plan to oc your cpu? Id personally get a cheaper cooler, and just get the 3900x
https://linustechtips.com/topic/1198418-motherboard-help/#findComment-13632156
Thanks. What would be a good cheaper cooler?
https://linustechtips.com/topic/1198418-motherboard-help/#findComment-13632160
Do you want to oc? Stock cooler may be ok but a bit louder, hyper 212 is a resaonble budget option, noctua nh u12s is a bit more of a premium. Of go all out and get a nh d15 or dark rock pro 4.
https://linustechtips.com/topic/1198418-motherboard-help/#findComment-13632167
No I am not thinking of overclocking. Is there a decent priced water cooler?
https://linustechtips.com/topic/1198418-motherboard-help/#findComment-13632177
16 minutes ago, Electronics Wizardy said:
If your not going to overclock, no point in a watercooling, the extra cooling won't help.
If overclocking isn't very hard for beginners, I am thinking I might try it in the future. What is the best not-so-expensive watercooler?
https://linustechtips.com/topic/1198418-motherboard-help/#findComment-13632240
Id stay away from a water cooler, and get a high end air cooler instead, something like a nh d15 or a dark rock pro 4
https://linustechtips.com/topic/1198418-motherboard-help/#findComment-13632866
