Hi everyone and thank you for passing by.
Specs to help: I7 6700k @4.4, Z170 Gaming 5 gigabyte mobo, 16GB CL15 3200Mhz ram, Corsair RM 750 PSU, Ryou 240 cooler.
My problem: I cannot get any clock stable over 4.4GHZ on my CPU, voltage at 1.3.
My question: I have tried to get anything above 4.4 but it does not seem to work, I can get 4.5 to work for a while but then at some poing my games will crash and or my PC will freeze sooner or later.
I have tried to set the voltage as high as 1.4 just to see if this would change anything but, Nah, it would not, I see so many people getting 4.7 without a problem.
Does anyone here know why this could be and or if I'm simply out of luck with my CPU and I got a "bad" one?
https://linustechtips.com/topic/1197996-overclocking-help/
Did you set LLC?
Desktop benching:
https://linustechtips.com/topic/1197996-overclocking-help/#findComment-13628470
9 minutes ago, Jakob11 said:
Sorry for my noobness, but what is LLC?
loadline calibration, so indeed you didnt touch it. Without it (by default it runs none) voltage dips a lot from idle to load (as current draw goes up)
Desktop benching:
https://linustechtips.com/topic/1197996-overclocking-help/#findComment-13628530
