GPU Upgrade, Help!
Go to solution Solved by UpTheDons,
7 minutes ago, KillerGamingBro said:
2070 Super can be found under 800 for me, thats not biggie.
My main issue is will I be bottlenecked badly if I buy something like these?
and then there is that, which I don't know if im ready to do especially since everything runs really well, just annoying with Doom eternal tbh.
yeah if everything is running alright wait longer for new releases which will drive prices down and then you can do a full upgrade. or buy parts as you go. e.g: by the gpu now, then get a b550 board when they drop to allow the upgrade path to ryzen 4000 then wait a bit to gather more money and get something along the lines 3600x or something like that.
Budget (including currency): 800 AUD
Country: Australia
Games, programs or workloads that it will be used for: Video and Photo editing and rendering. Autodesk Inventor, Aftereffects, Photoshop. Looking to play AAA titles at high.
I have had my current setup for a while and while it still goes pretty well although I struggle with high settings on newer games, and with only 3 GB VRAM on my GPU itll only run low on doom eternal.
On Doom Eternal I run it at 70 fps at the low texture settings, with everything else ultra but im looking for hopefully around 80 FPS at the high settings. This is all 1080p.
Any recomendations on what I should upgrade would be great, I'd like to keep the mobo if possible but it open to all ideas.
My Cpu is the Intel i5-6400  and my GPU is theSapphire Radeon R9 280x
I have 16 Gb DDR4 Ram on the Gigabyte GA-B150M-D3H.
Thanks in advance!
---Me Rig---
-CPU-
Intel i7-6700K
-GPU-
Gigabyte RX 5600XT OC 6GB
-STORAGE-
1x Western Digital 1TB HDD
1x Samsung M.2 1TB SSD
1x Crucial 275GB MX300 SSD
-RAM-
Team Group 2 x 8GB DDR4 2400mHZ
-PSU-
Corsair CX-M Series CX650M
-MOBO-
Gigabyte Z170X-Gaming 6
-CASE-
Phanteks P400S Satin Black TG Edition
-PERIPHERALS-
Logitech g502 RGB and Blackwidow Elite.
-PART PICKER URL-
https://au.pcpartpicker.com/list/Jf9tbj
Have a Nice Day, Give us a Thumbs up if I helped you, Why Not?
https://linustechtips.com/topic/1197220-gpu-upgrade-help/
Country: Australia
Thanks in advance!
a 5700xt or a 2060 super is around this price range you could stretch to a 2070 super if you have abit more money that you can find.
                                               JOIN THE FIGHT AGAINST COVID-19 BY RUNNING FOLDING AT HOME!!
        have a look at the thread below if your interested:
Home gaming and general work rig: CPU: 2700x with stock cooler Ram: Corsair vengeance pro RGB 16gb GPU: RX570 4GB (upgrading soon) Storage: 1x 500gb crucial SSD + 1tb HDD Mobo: B450-F gaming PSU: Corsair rmx550Case: Corsair 275R
F@H rig (In office and used for work too) CPU: 3600 Ram: Viper 16gb ram Mobo: B550-Tomahawk GPU's 1x 2080 super 1x 2060 super Storage: SN750 1tb Case: PC 011 Air PSU: Corsair RM850 Fans: 6x Noctua NF-12
Remember to quote me so I can see your reply!
Always Reply with a question if you have one! 😃
https://linustechtips.com/topic/1197220-gpu-upgrade-help/#findComment-13622741
Country: Australia
Thanks in advance!
i would upgrade the mobo if possible not sure about the cpu might be worth upgrading all 3 to be honest.
https://linustechtips.com/topic/1197220-gpu-upgrade-help/#findComment-13622749
---Me Rig---
-CPU-
Intel i7-6700K
-GPU-
-STORAGE-
-RAM-
-PSU-
-MOBO-
-CASE-
-PERIPHERALS-
-PART PICKER URL-
https://linustechtips.com/topic/1197220-gpu-upgrade-help/#findComment-13622781
i would say there may well be a bottleneck so replacing the mobo and cpu probably is the best idea you could always go with a cheaper GPU and then get a new cpu and mobo.
https://linustechtips.com/topic/1197220-gpu-upgrade-help/#findComment-13622789
https://linustechtips.com/topic/1197220-gpu-upgrade-help/#findComment-13622796
or of course go with a cheaper card that wont bottleneck like a 580 but its always worth upgrading if you have the cash as those parts are pretty old now and if you want the best performance on games in terms of FPS obvs more money is better. depends on what money you have available.
https://linustechtips.com/topic/1197220-gpu-upgrade-help/#findComment-13622809
thats a good idea, I will do that. Thanks for your advice!
---Me Rig---
-CPU-
Intel i7-6700K
-GPU-
-STORAGE-
-RAM-
-PSU-
-MOBO-
-CASE-
-PERIPHERALS-
-PART PICKER URL-
https://linustechtips.com/topic/1197220-gpu-upgrade-help/#findComment-13637838
