i am planning to upgrade to a ryzen 3600
and i want to overclock it
before overclocking i am going to need a new motherboard
if i buy a X570 motherboard do i also need to buy a new psu
if yes sucgestions
looking at the pin lay out i think i will
specs
UserBenchmarks: Game 68%, Desk 67%, Work 52%
CPU: AMD Ryzen 5 2400G - 61.2%
GPU: Nvidia GTX 1660-Ti - 73.2%
SSD: Corsair Force MP300 NVMe PCIe M.2 120GB - 108.2%
SSD: Samsung 860 Evo 500GB - 89.5%
HDD: WD Green 1TB (2011) - 74.8%
HDD: Seagate Momentus 2.5" 1TB - 51.7%
USB: Intenso Rainbow Line 4GB - 3.5%
RAM: Corsair CMW16GX4M2Z3600C18 2x8GB - 96.5%
MBD: MSI B350M GAMING PRO (MS-7A39)
psu: bequiet system power 8 pro 600w
cooler: corsair h100i pro rgb
https://linustechtips.com/topic/1197010-psu-upgrade-required/
That looks just fine from here.
At me or quote me, I want to hear your opinion.
Hopefully anything I say is factually correct. Sorry for any mistakes in advanced.
https://linustechtips.com/topic/1197010-psu-upgrade-required/#findComment-13621099
psu is fine
3600 uses 100-120w max incl. overclocking
your video card ~125-150w
the rest around 35-50w
so if you go over 3oow id be surprised
Up to a 3900x you only need a 8 pin EPS connector, if the motherboard has 2 8 pin connectors you can leave the 2nd connector empty
a single 8 pin connector can give 300w to the cpu, and a 3600 with overclocking only eats up to 100-120w like i said.
even  a 3950x can function with a single 8 pin connector, but a second connector is encouraged, to spread the current through more wires.
https://linustechtips.com/topic/1197010-psu-upgrade-required/#findComment-13621105
2 minutes ago, pjotrdegraaf said:
beacus the pin layout on a x570 looks different
It's possible it has a dual 8 pin cpu connector, but usually you can get away with 1.worst case scenario you can find an adapter.
https://linustechtips.com/topic/1197010-psu-upgrade-required/#findComment-13621114
if i waned to buy a new psu what woud you reccomend?
PC part picker? Amazon? I don't have brand loyalty when it comes to psu's, especially as prices change so much.
https://linustechtips.com/topic/1197010-psu-upgrade-required/#findComment-13621125
