High ping between 2 PCs on the same network...
Hello I need help, pinging my brother in cmd gives out a high ping even though we're in the same network. What could usually cause this and how can I remedy it?
Sidenote, ping sometimes lowers to 3-7ms but at times it fluctuates to 50-500ms which makes LAN games like minecraft unplayable. Help please!
Motherboard: MSI B450m Mortar Max
Processor: Ryzen 7 2700 w/ Wraith Prism
RAM: Klev Cras X 3200mhz 8gb x2
GPU:  Zotac Mini GeForce GTX 1070ti 8GB
PSU: Seasonic GX-750
Case: Inplay Robin 101 + 10 fans w/ hub and remote
Storage: Toshiba 1TB, Western Digital WD Green 1TB, Crucial BX500 480GB
https://linustechtips.com/topic/1196763-high-ping-between-2-pcs-on-the-same-network/
1 minute ago, -Gandolf- said:
What kind of ping do you get when playing onine games?
If it is high too it could be your router.
Also if you are using Wifi try moving your PCs, there could be something interfering with your signal.
I get a low and stable ping of around 20-30 at max 60 when playing games like League, so I don't think online games are affected by this for some weird reason.
What is your network setup like (makes/models of specific devices and ethernet/wireless)?
12 minutes ago, Falcon1986 said:
What is your network setup like (makes/models of specific devices and ethernet/wirelesses
It's a Skyworth cm5100.g2 modem
Wired or WiFi?
