So here I am again.. I ran Unigine for about 30 minutes, on the max settings extreme or whatever 1920x1080, for the first 10 minutes or so my GPU stayed around 75 - 78c and then It seemed to max my GPU temp at 83/84 it was going back and forth between the two temps. Should I be fine with those temps? or tonight should I run it while I sleep or just don't even worry? I read that problems start after the 87c mark and anything below should be fine.
and no I didn't get a link to my results I forgot how lol I clicked quit and it didn't give me any link or whatever so idk
4, 8, 15, 16, 23, 42
https://linustechtips.com/topic/1196330-unigine-gpu-temp/
Low 80s is warm, but not dangerously so. You'll be loosing some GPU boost clock speed but shouldn't be thermal throttling yet.
You could try tweaking the fan curve on the GPU to bring temps down a little, provided you're okay with additional fan noise.
Edited by RAS_3885
Typo corrected: SHOULDN'T be thermal throttling...
Be sure to QUOTE or TAG me in your reply so I see it!
CPU Ryzen 7 5800X3D GPU EVGA 3080 Ti FTW3 Ultra MOBO Asus ROG Strix B550-F Gaming RAM Crucial Ballistix 3600 MHz CL16 32 GB PSU Corsair RM1000x COOLING Noctua NH-D15
https://linustechtips.com/topic/1196330-unigine-gpu-temp/#findComment-13616043
These temps are fine
Especially because you are running a stress test
A gpu won't ever work that hard in a game
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1196330-unigine-gpu-temp/#findComment-13616060
