I have been using a software called LanCache to setup a steam cache, and I cannot connect to my server. I have set the DNS on my PC to the server's IP address which is static, but when I run NSlookup I get this:
(Me)>nslookup cache.steamcache.lancache.net
Server:  UnKnown
Address:  10.0.0.254
*** UnKnown can't find cache.steamcache.lancache.net: No response from server
It does find the correct IP address, but it won't work.
https://linustechtips.com/topic/1196215-lancache-issues/
  Hide contents
Server:  UnKnown
Address:  10.0.0.254
Well your computer is still trying to use 10.0.0.254 for DNS, isn’t the server’s IP 10.0.0.253 now?
Looking to buy GTX690, other multi-GPU cards, or single-slot graphics cards:
https://linustechtips.com/topic/1196215-lancache-issues/#findComment-13615082
No, 253 would be dynamic because its in the DHCP range. The server's IP was 255 but then we put it to 254 so it would work.
https://linustechtips.com/topic/1196215-lancache-issues/#findComment-13615085
Sorry I went back to the other thread and reread. I forgot.
So we made sure the server is on the right IP. At this point I can think of two things:
-firewall on the server is blocking all inbound connections - need to allow in UDP/53
-docker network config is incorrect, need to make sure that port 53 on the host is being passed to port 53 of the container. This is basically the same as port forwarding on a router.
I don’t have enough experience to give you exact instructions on either of these.
Edit: also, make sure you can ping the server from the computer. Note that linux default firewall allows incoming pings, windows default firewall does not. So if you make no firewall changes, you can ping from a windows computer to a linux one but not vice-versa.
https://linustechtips.com/topic/1196215-lancache-issues/#findComment-13615090
No problem. I don't really use Linux much, but I think the firewall is off.
https://linustechtips.com/topic/1196215-lancache-issues/#findComment-13615114
I have played around a bit and done some research but I can't really find much on how to pass through ports to docker. If you could find like a video or article on how to do this, I will do my best to follow it. I will keep looking.
https://linustechtips.com/topic/1196215-lancache-issues/#findComment-13615299
I’m pretty sure its in the command when you create the container. For example:
Quote
docker run --name lancache-dns -p 10.0.0.2:53:53/udp -e USE_GENERIC_CACHE=true -e LANCACHE_IP=10.0.0.3 lancachenet/lancache-dns:latest
Would pass 10.0.0.2 (replace with the host’s actual IP) port 53 to port 53 of the container.
https://linustechtips.com/topic/1196215-lancache-issues/#findComment-13617344
I did not use a command such as this. I just installed docker via Git, edited the config files with a nano command, and used "docker-compose up -d" to start lancache. Then it ran a ton of scripts and stuff. I just did what was in this video.
https://linustechtips.com/topic/1196215-lancache-issues/#findComment-13617677
You may not have used a command like that, but it would have been in the scripts that were run. It *should* have included the assignment of udp/53 to the container, but when things aren’t working, I trust nothing.
https://linustechtips.com/topic/1196215-lancache-issues/#findComment-13617954
1 hour ago, Sehaj (Linus & Nicky V. F) said:
Hi guys so I really wanted to get a NAS but the only problem is I am not able to justify its cost bcos the only use I have is that I am going to use it as a steam cache, is there any other use u guys can think of ?
If your budget is that strict, how many computers do you have the same game installed on? a Steam cache may be pointless for you....
Desktop: Ryzen9 5950X | ASUS ROG Crosshair VIII Hero (Wifi) | EVGA RTX 3080Ti FTW3 | 32GB (2x16GB) Corsair Dominator Platinum RGB Pro 3600Mhz | EKWB EK-AIO 360D-RGB | EKWB EK-Vardar RGB Fans | 1TB Samsung 980 Pro, 4TB Samsung 980 Pro | Corsair 5000D Airflow | Corsair HX850 Platinum PSU | Asus ROG 42" OLED PG42UQ + LG 32" 32GK850G Monitor | Roccat Vulcan TKL Pro Keyboard | Logitech G Pro X Superlight  | MicroLab Solo 7C Speakers | Audio-Technica ATH-M50xBT2 LE Headphones | TC-Helicon GoXLR | Audio-Technica AT2035 | LTT Desk Mat | XBOX-X Controller | Windows 11 Pro
Server: Fractal Design Define R6 | Ryzen 3950x | ASRock X570 Taichi | Asus RTX 4060 Dual OC | 64GB (4x16GB) Corsair Vengeance LPX 3000Mhz | Corsair RM850v2 PSU | Fractal S36 Triple AIO + 4 Additional Venturi 120mm Fans | 8 x 20TB Seagate Exos X22 | 4 x 16TB Seagate Exos X18 | 3 x 2TB Samsung 970 Evo Plus NVMe | LSI 9211-8i HBA
NAS: Innovision 4U 24-bay chassis (12GB MiniHD SGIO Backplane) | Intel Core i9-10980xe | EVGA X299 FTW-K | EVGA RTX 2080Ti Super FTW3 | 128GB (8x16GB) Corsair Vengeance LPX 3200Mhz | DEEPCOOL PN1000M PSU| Noctua NH-D12L Chromax Black | 16 x 16TB Seagate Exos X18 | 2 x 2TB Samsung 990 Pro | 2 x 2TB Intel U.2 P4510 | LSI 9305-24i HBA
https://linustechtips.com/topic/1196215-lancache-issues/#findComment-13618060
