  1. System configuration
    • MOBO: asrock AB350 PRO4
    • CPU: Ryzen 3 1200
    • Memory: T-Force DDR4-3200
    • GPU: Geoforce 9800 GT
    • PSU: 750W
    • Storage: WD 1 TB, 2x WD 500GB
  2. Troubleshooting steps you already did
    • Unplugged all connections and reconnected
    • Unplugged everything but the memory, cpu, and gpu
    • Unseated and reseated ram
    • Removed second stick of ram
    • Switched an tried other stick alone
    • Checked monitor and display cable
    • Connected speaker to listen for beeps (It didn't beep at all)
  3. Any additional information that may be relevant.
    • I tested the system before installing it in the case and it posted and everything was visible in the BIOS. But after installing it and turning it on the fans spin up but nothing happens. I am very new to working on computers and this is my first build so I don't know what else to try. I plugged a speaker in but it does it does not beep at all when I power it on. When it posted before the fans came on full power and then slowed down before it posted but that is not happening now, the fans just run at full speed. The other weird thing is that it powers on as soon as I plug it in, I don't press the power button at all. Thank you for your help!
https://linustechtips.com/topic/1196151-no-post-after-installing-in-case/
Motherboard standoffs properly installed?
Faulty power switch on the case? Which case is it?
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
I'm not connected to the power switch on the case, and I can try removing the board from the stand offs and see what happens.
