Budget (including currency): Fairly high
Country: Denmark
Games, programs or workloads that it will be used for: CS:GO, Assassins creed = gaming only
Other details (existing parts lists, what resolution and refresh rate you want to play at, etc):
Part list, i was thinking:
Tower: Corsair obsidian 1000D
Motherboard: ROG Maximus XII Extreme
CPU: I9-10900k
Ram: G.skill trident z Royal  DDR4-4600 - GOLD - 16gb (2x8) will be upgrading to 32gb at some point
SSD 1: 1TB - Samsung 970 Evo Plus 1 TB M.2-2280 NVME
SSD Windows: Samsung 970 Evo Plus 250 GB M.2-2280 NVME
HDD: Seagate Barracuda Compute 2 TB 3.5" 7200RPM
PSU: Asus 850p 80+ Platinum
GPU: i was thinking the -> 3080 ti
CPU Cooler: i was thinking the -> kraken z73 = if it fits LGA 1200 ?? (i dont know if it does)
please tell me what you think ?
https://linustechtips.com/topic/1194873-need-help/
Country: Denmark
CPU: I9-10900k
4600MHz RAM?
Uhh I'm not sure if you'll even use that much of it, and even if you do its not worth it, better get a 3600MHz one and with that money get yourself better equipment?
Or if you say,
no bro im rich just gimme the best of the best even if it wont matter that much I still want it i dunno why,
Well youre free but just saying
https://linustechtips.com/topic/1194873-need-help/#findComment-13604969
3 minutes ago, dbpx2 said:
4600MHz RAM?
Or if you say,
i just dont know that much about computers its about 1.5 month sallery for the system
ill be getting all new razer equipment if thats what you mean ?
but will it all fit together ? and does the kraken z73 support LGA 1200 ?
and is 3600Mhz enough ? because then i cant get 64 gb ram for the same price as 32bg 4600Mhz ?
https://linustechtips.com/topic/1194873-need-help/#findComment-13605000
Kraken Z73 is compatible with socket LGA1200.
Well I dont think 4600MHz RAM is worth it, and if I were you I would go for a better PSU with the money left from the RAM maybe, like 1000W 80+,
It all seem to be compatible with each other and theyll fit. But i9 10900K will produce LOTS of heat I guess, so take a good cooler.
And if you want to just get quality products with decent performance, DEFINITELY go for Razer.
I mean you can get better performing peripherals with the same price or lower, but quality and comfort is another thing. I have a razer equipment myself, razer aims to bring people the ultimate gaming peripherals, you know, I was not going to spend so much on peripherals but still I got razer because headsets are too comfortable, mouse is too ergonomic and feels great, and everythings are looking so stylish together..
and another question is when will the 3080 ti be released ?
In september I believe.
https://linustechtips.com/topic/1194873-need-help/#findComment-13605044
ya i feel the same about razer i have always used razer.
but better PSU next in line would be the asus 1200p 80+ platinum
If you have any great "water coolers" in mind please tell
i am not up for costume cooling i have been told it takes a lot of mantaning
I was told kraken z73 was one of the best on the market
https://linustechtips.com/topic/1194873-need-help/#findComment-13605080
(and about the ram)
G.Skill Trident Z Royal Gold DDR4 3600MHz 4x16GB =64GB = $492.84
vs
G.Skill Trident Z Royal RGB Gold DDR4 4600MHz 4x8GB=32GB = $909.36
https://linustechtips.com/topic/1194873-need-help/#findComment-13605194
(and about the ram)
vs
About RAM, dont go with 64GB coz probably you wont play any game that requires that much of RAM with even that computer.
https://linustechtips.com/topic/1194873-need-help/#findComment-13605272
