8 minutes ago, BlueEyesWhiteDragon said:
Swaping the mother board, and CPU wont require a new product key will it?
If you have an OEM key, changing your motherboard may invalidate your license. Otherwise, you should be fine.
7 minutes ago, BlueEyesWhiteDragon said:
like can I use my old hard drive on a new upgrade?
Assuming you're referring to the drive with your Windows install, note that it is generally recommended that you reset your Windows install if you decide to change platforms.
Make sure to quote me or use @PorkishPig to notify me that you replied!
Desktop
CPU - Ryzen 9 3900X | Cooler - Noctua NH-D15 | Motherboard - ASUS TUF X570-PLUS RAM - Corsair Vengeance LPX DDR4-3200 32GB Case - Meshify C
GPU - RTX 3080 FE PSU - Straight Power 11 850W Platinum Storage - 980 PRO 1TB, 960 EVO 500GB, S31 1TB, MX500 500GB | OS - Windows 11 Pro
Homelab
CPU - Core i5-11400 | Cooler - Noctua NH-U12S | Motherboard - ASRock Z590M-ITX RAM - G.Skill Ripjaws V DDR4-3600 32GB (2x16)  | Case - Node 304
PSU - EVGA B3 650W | Storage - 860 EVO 256GB, Sabrent Rocket 4.0 1TB, WD Red 4TB (x6 in RAIDZ1 w/ LSI 9207-8i) | OS - TrueNAS Scale (Debian)
https://linustechtips.com/topic/1194560-will-it-be-faster/#findComment-13602391
Ensure the motherboard supports your cpu
You should be fine to use the same hard drive.
Also check Linus' video on why they pirate windows, as it shows what parts can usually be swapped and have windiws still work
Ryzen 5 3600
MSI B550 Tomahawk
16GB 3600mHz Trident Z RGB
1650 Super
Fractal Design Meshify C
Samsung 970 Evo 1TB
https://linustechtips.com/topic/1194560-will-it-be-faster/#findComment-13602393
If you tallking about WIndows. No, you dont need a new Key.
And yes, you can of course use your old HDD, if it isnt IDE.
CPU i7 6700k MB  MSI Z170A Pro Carbon GPU Zotac GTX980Ti amp!extreme RAM 16GB DDR4 Corsair Vengeance 3k CASE Corsair 760T PSU Corsair RM750i MOUSE Logitech G9x KB Logitech G910 HS Sennheiser GSP 500 SC Asus Xonar 7.1 MONITOR Acer Predator xb270hu Storage 1x1TB + 2x500GB Samsung 7200U/m - 2x500GB SSD Samsung 850EVO
https://linustechtips.com/topic/1194560-will-it-be-faster/#findComment-13602401
