Most likely not, but can't say for certain. 6pin is propitiatory connector, so would need to know pinout on both ends. Otherwise you risk breaking both.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/1194535-6-pin-fan-controllers/#findComment-13604482
