Budget (including currency): 1200ish GBP, can be higher though
Country: UK
Games, programs or workloads that it will be used for: Image editing, video editing, maybe light games, admin things for work
Other details
PCPartPicker Part List: https://uk.pcpartpicker.com/list/gqxLBZ
CPU: AMD Ryzen 7 3700X 3.6 GHz 8-Core Processor  (£260.73 @ Amazon UK)
CPU Cooler: NZXT Kraken X53 73.11 CFM Liquid CPU Cooler  (£119.99 @ Box Limited)
Motherboard: Asus ROG STRIX B450-E GAMING ATX AM4 Motherboard  (£145.47 @ Scan.co.uk)
Memory: G.Skill Trident Z RGB 32 GB (2 x 16 GB) DDR4-3600 Memory  (£188.36 @ CCL Computers)
Storage: Western Digital Blue 500 GB 2.5" Solid State Drive  (£59.97 @ Amazon UK)
Storage: Seagate Barracuda Compute 2 TB 3.5" 7200RPM Internal Hard Drive  (£52.88 @ CCL Computers)
Video Card: Sapphire Radeon RX 580 4 GB NITRO+ Video Card  (£213.99 @ Amazon UK)
Case: be quiet! Pure Base 500 ATX Mid Tower Case  (£94.03 @ Novatech)
Power Supply: be quiet! Straight Power 11 550 W 80+ Gold Certified Fully Modular ATX Power Supply  (£99.98 @ Amazon UK)
Total: £1235.40
Is this a good list? Should i choose the 9700k over the 3700x?
Also, does the motherboard need a bios update for 3000 support? The asus website says yes but some other places say no.
https://linustechtips.com/topic/1194217-productivity-pc-help/
depending on your video editing program of choice you may be able to utilize quicksync on intel cpus
gaming system: Intel core I9 12900ks / biostar Z690A valkyrie / 4x8gb corsair Vengeance @3333Mhz ram / RX 7900XTX pulse gpu / Thermalright peerless assassin 140 /Coolermaster Qube 500 case / Be Quiet Dark Power Pro 12 1500w power supply
laptop: Dell xps 9510, 3.5k OLED, i7 11800h, rtx 3050 ti, 2x16gb DDR4 @ 3200Mhz, 1TB main drive, 2TB add in ssd
https://linustechtips.com/topic/1194217-productivity-pc-help/#findComment-13600058
