Skyrim ENB problem.
Go to solution Solved by cam_sally,
Make sure that you have done all the correct SkyrimPrefs.ini tweaks in your my documents folder (not the game folder). Could also be a conflicting mod
Thank you, fellow members of LTT. You helped me make my skyrim look F***ing beautiful!
post-45390-0-42555000-1393120731_thumb.j
Intel Core i7 4770k - 2x Geforce GTX 780 - MSI Z87 MPower Max - Corsair H60 - 8GB Avexir Core Series MPower Yellow + 4gb no-brand DDR3 - Corsair Obsidian 750d - AData XPG SX900 256gb SSD - Seagate Barracuda 3TB (7200 RPM) - Hitachi 250GB 2.5in HDD (3200 RPM) - WD HDD 160GB extracted from iMac via black magic (no specified RPM) - ASUS VG248QE 144HZ 3d Vision Monitor - Logitech G602 - Ducky Shine 3 TKL - AKG 172 HD Headphones - Xperia z2 - Sony Noise canceling earphones -  Nikon D5200 With Bundled Lenses - Windows 7 Home Premium - Blue Snowball iCE - Acer Aspire X with a broken case, AMD A6, and Raijintek Aidos CPU heatsink
https://linustechtips.com/topic/119407-skyrim-enb-problem/
What enb?
Muh rig: i7 4770k, Cooler Master Hyper 212 Evo, MSI Z87 G45, Kingston Hyper X Blu 8GB, Samsung 840 EVO 120 + WD Blue 1 TB, Asus GTX 770 2GB, Corsair 200r + 2x Corsair AF 120 Blue + 1x Stock corsair fan, Corsair TX650, LG 27EA33V IPS, Steelseries Sensei Raw + QCK mini, CM Quickfire Ultimate Blue.
https://linustechtips.com/topic/119407-skyrim-enb-problem/#findComment-1591617
What enb?
Realvision.
https://linustechtips.com/topic/119407-skyrim-enb-problem/#findComment-1591621
Did you follow all the steps on the mod page? Realvision is not just a mod you install with NMM.
https://linustechtips.com/topic/119407-skyrim-enb-problem/#findComment-1591648
What do you mean?
https://linustechtips.com/topic/119407-skyrim-enb-problem/#findComment-1591808
Yes.
https://linustechtips.com/topic/119407-skyrim-enb-problem/#findComment-1591811
