Hi,
My in laws are wanting to build a new pc and have provided the following components. Just want to get some input is there better options in the price points or is that pretty solid. They are looking at around the 1700 AUD so about $1100 USD
Pasting the links to the local store that i usually use.
AMD Ryzen 5 3600 6 Core AM4 3.6GHz CPU  https://www.umart.com.au/AMD-Ryzen-5-3600-6-Core-AM4-3-6GHz-CPU-with-Wraith-Stealth-Cooler_51578G.html
MSI B450M Pro VDH Max mATX AM4 Motherboard https://www.umart.com.au/MSI-B450M-Pro-VDH-Max-mATX-AM4-Motherboard_53435G.html
2 X G.Skill 8GB (1x8GB)F4-3200C16S-8GIS Aegis 3200MHz DDR4 RAM https://www.umart.com.au/G-Skill-8GB--1x8GB-F4-3200C16S-8GIS-Aegis-3200MHz-DDR4-RAM_53047G.html
Silicon Power 512GB NVMe PCIe Gen3x4 M.2 2280 TLC SSD https://www.umart.com.au/Silicon-Power-512GB-NVMe-PCIe-Gen3x4-M-2-2280-TLC-SSD--Internal-Solid-State-Drive--SP512GBP34A80M28_50734G.html
Seagate Barracuda 2TB 3.5in SATA3 256MB Cache Hard Drive https://www.umart.com.au/Seagate-Barracuda-2TB-3-5in-SATA3-256MB-Cache-Hard-Drive-ST2000DM008_48625G.html
MSI GeForce RTX 2060 Ventus XS 6G OC Graphics Card https://www.umart.com.au/MSI-GeForce-RTX-2060-Ventus-XS-6G-OC-Graphics-Card_49580G.html
Cooler Master Hyper 212 LED Turbo CPU Cooler Red Cover https://www.umart.com.au/Cooler-Master-Hyper-212-LED-Turbo-CPU-Cooler-Red-Cover_38264G.html
Cooler Master MWE Gold 750W 80 Plus Gold Power Supply https://www.umart.com.au/Cooler-Master-MWE-Gold-750W-80-Plus-Gold-Power-Supply_44574G.html
Cooler Master MasterBox K501L Mid Tower ATX Case https://www.umart.com.au/Cooler-Master-MasterBox-K501L-Mid-Tower-ATX-Case_52702G.html
Feedback would be great.
https://linustechtips.com/topic/1193583-new-system-help/
6 minutes ago, nextg3n said:
the only stepping stone i see is between the mobo and the cpu, need to update bios before that cpu will run properly. otherwise nice and solid.
MAX Motherboards come 3rd gen Ryzen ready from the factory so i wouldn't worry about that.
But i would worry about the crap quality VRMs,also B450 is a dead end due to a recent announcement from AMD.
I would either wait for B550 or outright buy a X570 board.
A PC Enthusiast since 2011
AMD Ryzen 7 5700X@4.65GHz | GIGABYTE RTX 3080 GAMING OC | 4x 8GB Micron Rev.E (D9VPP) 3800MHz 16-19-14-21-58
https://linustechtips.com/topic/1193583-new-system-help/#findComment-13595197
@Vishera to go to the X570 you are doubling the price of that mobo. which pushes past the budget range. Is there another model you would look at though?
Is there any reason not to go for the 450 even though it will be superseded?
They are planning to use the system to game but would not be doing much, if any, overclocking.
https://linustechtips.com/topic/1193583-new-system-help/#findComment-13595214
i know that(ive looked out to build the same combo) but ive seen some strange bs with them also so just a headsup.
Some EU input to Canadian IT :D
https://linustechtips.com/topic/1193583-new-system-help/#findComment-13595250
19 hours ago, Zelpha said:
@next3ngl is that the 450 in general having some strange bs with them or is it that mobo specifically?
That motherboard is cheap crap - I wouldn't expect much out of it.
If you want a decent B450 board the B450 Tomahawk Max is very good and can handle a 3950X if you want to upgrade in the future.
https://linustechtips.com/topic/1193583-new-system-help/#findComment-13598968
