5700XT Vulkan Issues
Go to solution Solved by PAPO1990,
Well I thought I'd chime back in now that I've seemingly fixed it. I had to dig around in the Windows registry after DDU-ing and delete every entry related to AMD gfx drivers and Vulkan. Now that it's working I'm SUPER happy with the performance, and I won't have to try and sell it for a 2nd hand 2080 :P .
Now I just have an issue with the Bethesda.net launcher for Doom Eternal, but I can launch it from the .exe so I'll make do.
Long time viewer, new forum-er... But I'm getting a bit desperate.
I recently upgraded to a 5700XT Liquid Devil (from an R9 390X), and after solving a bunch of issues, I'm left with Vulkan not working.
Diagnosis:
Doom Eternal: Won't launch
Doom (2016): Wouldn't launch until I changed the config to use Open GL
3D Mark: In the API overhead test the Vulkan test simply doesn't happen
GPU-Z: The Vulkan box is not checked in the features at the bottom.
So Far:
Yes I've DDU'd MULTIPLE times, I've tried a few different versions of the driver.
My MoBo Bios is up to date
Windows is up to date (or was yesterday, some small updates next time I reboot but I doubt that'll do much)
I've run "sfc/ Scannow" with no issues found.
Pls Help. I'd like to finish Doom Eternal (I started it on my 390X) and a Vulkan wrapper seems to be the solution to Test Drive Unlimited 2 being broken (yes it's an old dead game, but there's some community support to keep it running, and I WAS playing it on my 390X).
https://linustechtips.com/topic/1193540-5700xt-vulkan-issues/
  • 3 months later...
https://linustechtips.com/topic/1193540-5700xt-vulkan-issues/#findComment-14014713
