https://linustechtips.com/topic/1191717-pc-build-help/#findComment-13580903
-Split-
You need to post your own new thread. Don't intrude on someone else's.
https://linustechtips.com/topic/1191717-pc-build-help/#findComment-13581392
I'd stay away from that motherboard. The thermals were terrible on it. MSI's budget 570's aren't up to task. I'd also spend a bit more on a bigger capacity SSD. 256gb is ok if you're using it for just the OS and a couple of games and applications but, most likely, you're going to wish you got something bigger. Overall, I think you could save some money by cutting back on some peripherals and opting for better core components but it's up to you, really. Just avoid that motherboard.
https://linustechtips.com/topic/1191717-pc-build-help/#findComment-13581432
