help me
Go to solution Solved by nova99,
yes it have
hello Mr. Linus
I need help for you. I have gtx 1080ti, i7 9700kf, z390 aorus elit, 700w power supply and 16 ram. My gtx disconcet motherboard and secreen become black when i start to play games. the temperature is no more 75 c of gpu and cpu is no more 56 c. i chanege theremaltak and i make fun 100% but it stell disconnected. what that mein?  can you help me please?
sorry about my engilsh so bad.
https://linustechtips.com/topic/1191585-help-me/
4 minutes ago, nova99 said:
hello Mr. Linus
I'm not Linus but hi
So am I getting this correctly
Under load or while playing games your screen turns black
(No offense but I don't necessarily understand I could be just dumb )
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1191585-help-me/#findComment-13580748
23 minutes ago, nova99 said:
hello Mr. Linus
Reinstall GPU Driver.
https://linustechtips.com/topic/1191585-help-me/#findComment-13580786
Just now, nova99 said:
i do it but same 😔
How old is your PSU and can you please tell us the exact model of it
Build Log:
https://linustechtips.com/topic/1191585-help-me/#findComment-13580800
2 minutes ago, nova99 said:
700w power supply and it is from black wido fullmodular. i have it from 4 month
Does it have an 80plus rating like a 80 plus bronze or something along those lines ?
Build Log:
https://linustechtips.com/topic/1191585-help-me/#findComment-13580869
9 minutes ago, nova99 said:
yes it have
Update your firmware to the latest one and see if that helps
Build Log:
https://linustechtips.com/topic/1191585-help-me/#findComment-13580887
11 minutes ago, nova99 said:
i uptodate my Windows every week and nvidia
I connect gtx 1660 super and i don't facing any problem with it but my problem only with gtx 1080ti
Update the firmware or the vbios in other words for your GPU
Not the drivers
Hope this helps :D
Build Log:
https://linustechtips.com/topic/1191585-help-me/#findComment-13580919
again my gpu start black secreen when i play games please anyone can help me to tell liuns about this problem because many people have same problem and they cant fix it.
my pc
z390 aorus elit
gtx 1080ti aorus
intel core I7 9700kf with deepcool water color
16gb ram
700 w 80+
500 gb ssd
4 tp hdd
Edited by nova99
https://linustechtips.com/topic/1191585-help-me/#findComment-13584997
