I have two graphics cards in my computer, a radeon r9 200, and a radeon 7900, and whenever I have the 7900 plugged in, the computer won't boot, or display on either graphics card, but then, when I unplug the 7900 from the power supply, the R9 works fine, and I don't have any shops or friends around me that have a graphics card that I can test with. Could this be a problem with the power supply, or drivers, or would it be a dead graphics card? If I unplug the R9, and leave the 7900 connected, the computer will boot, but wont display anything.
I have a few theories based on my expeirence with cross-generational multi-GPU configs, but I'd have to know your PC specs before making any assessments.
Could you supply your CPU, Motherboard vendor (and chipset/model number if possible), and any other PCI/PCIe cards you have connected?
If you can post that info I'll see what I can do for ya :)
I just noticed you responded, its a Sabertooth 990fx motherboard, amd fx-8350 processor, 16 gigs of ddr3 vengeance ram, the radeon r9 200 and radeon 7900. And its all watercooled. I'd have to check the powe rsupply sometime, but i think its a corsair 500 watt.
I think it's the gpu that is dead
Power delivery gets worse over time and this is a pretty old GPU So I havey doubts that I'd will be able to display an image
Phone: Pixel 3a (Purple-ish).
Build Log:
Alright. I'm gonna bring it to someone to test, and if it is bad, I'll probably just replace till I can build a new system.
Good luck
Build Log:
