Specs:
GTX 1060 6GB
Ryzen 7 2700x (OC'd to 4001 MHZ constant)
Corsair Vengeance RGB pro 3200MHZ C16 2x8 GB
500 Watt PSU (More than enough, even under heavy load)
MSI B450 Gaming Plus Max
When I try to enable either A-XMP profile, it does nothing and makes my CPU run at stock speed (3.7 GHZ) alongside my RAM at 2133mhz
In MSI memory try it, I load the settings for my ram (from CPU-Z) and it still defaults to stock speed for my CPU and RAM. I have tried a higher and lower clock speed and timings and both gave the same result.
I've tried changing the memory frequency from auto (2133) to 3200MHZ, and setting all the clocks manually after getting them from CPU-Z, and it still reset the CPU to stock speed and the ram to 2133
I've tried re-seating the RAM.
My bios is up to date
Motherboard max RAM speed is 3466
Any help would be greatly appreciated. :)
https://linustechtips.com/topic/1190905-trouble-with/
Okay, I tried posting the memory at 2933 with A-XMP profile 1 and memory try it but they both yielded the same result, CPU at 3.7GHZ and RAM at 2133. Would turning on A-XMP profile 1 and changing my CPU clock to 4Ghz and memory clocks to 2933 in Ryzen Master work?
https://linustechtips.com/topic/1190905-trouble-with/#findComment-13577456
